84 Grand Marquis not starting
Old Jul 15, 2008 | 12:22 PM
maxteca's Avatar
I have a 84 Grand Marquis that is not starting. It is getting spark and
fuel but all it dose is turn over kind of slow. What it did is I was driving it and it just died and would not start again.
Old Jul 16, 2008 | 03:07 AM
Mercury fan's Avatar
Have you checked the engine and battery?
Old Jul 16, 2008 | 09:21 PM
maxteca's Avatar
New battery and cap and rotor, coil, plugs and wires.
Old Jul 16, 2008 | 10:17 PM
jason sereiko's Avatar
If it is a new battery, check the cables and make sure they are tight. a new battery can be defective, get it checked at the store like autozone.
Old Jul 16, 2008 | 10:19 PM
check the volts on the battery with a volt meter. then check the volts at the starter. meters run about 10-50 bucks for cheap to good ones
Old Jul 16, 2008 | 10:27 PM
check the fuel pressure with a gauge, it should be 30-35psi
Old Jul 17, 2008 | 12:57 AM
maxteca's Avatar
I did everything mentioned above. One thing I did not mention it dose is
it only gets spark at the coil when you first try and start it then no spark.
Edited by: maxteca
Old Jul 17, 2008 | 12:22 PM
does this have eight coils ore one. Are the eight coils mounted on the valve covers or are they in packs of four?
Old Jul 17, 2008 | 12:23 PM
  #9
I would take off the coils or coil and have the resistence checked at a parts store. Have them check the whole thing.i know autozone does it for free!
Old Jul 17, 2008 | 04:54 PM
  #10
maxteca's Avatar
Only one and I took the one coil in and had the resistance checked.
