89-How to remove headlight switch?
Any idea how to remove the stupid headlight switch so we can remove the panel? We've tried twisting, pulling gently, and searching all over the web. Is there some kind of trick to this; it seems it should be easy, but we've been trying for some time! Thank you!
there is a spring clip in the knob you can press with a fish hook to release pressure so knob comes off the light switch arm... or tug the knob off and then take the metal clip off the arm and reinsert it back in the knob... doin this will allow the trim to be pulled off since the knob is biggest thing in the way... by pulling hard on the knob it will slide off and wont hurt your light switch... just make sure to put the spring clip back in the knob and push back on the arm when done.. i saw your post on GMN and here so thought this might help here
Thanks, 87_Crown_Vic! I was beginning to wonder if anyone would reply on this site! Your idea seems the easiest....that IS for an 89 Grand Marquis, right? Are you saying the release is within the knob..and not the entire switch box (which is behind the panel). If I just yank it off...do I need to have the know set in any set direction, or will any setting work? Hey...I'm so glad to hear from you. We gave up yesterday, but will try again this evening.
your 1989 is set up like a 1992 i just did to remove the speedometer... there is a release button behind dash to release the entire rod from the light switch... but you can also just remove knob so that the trim can slide over the rod instead of removing it... i have worked on 1986 and newer ... in 1988 Ford/Mercury changed dash styles for trim and stuff and in 1990 and newer the really changed the dash to where there werent even speakers in the dash anymore. i am familiar with what you are trying to do and figured it would be easier to respond here than on GrandMarq.NET ... if i get to it i will get a few pics of how the knob pops off the rod to let you know what i mean by the spring clip that removes the knob from the rod instead of the whole rod assembly like others suggested...
i have an account with alldata pro and the correct way is to hit the release button and the only way i have found to do this is remove the fuse panel and stick a looong flat head through the hole and hit the button my hands are small so i can reach it but barley and it hurts so yea lon flat head through the fuse panel and there is a small black button that lets the light knob come out easy
Thanks, Craka D! I'm going to try that! I will report back if I can do it. Thank you, again! :) luckyfish
| All times are GMT -5. The time now is 10:36 AM. |
