92 gm
what parts should i buy to beef up my gm?
generally a cold air intake and dual exhaust will make that car pick up much better. There are aftermarket options for that year that are bolt on. You can also get the H-pipe and driver side tail pipe from most parts stores (though welding is required to hang it properly) and just add a muffler to make it all fit.
much more than that and you'll be getting into some serious custom work. |
I guess to best anser your question, what and how much do you wanna beef up? Power, Handling, durability?
As Slymer mentioned, exhaust and a cold air intake a a good start on the engine... Getting a little more in depth for options: heads cams and intake from a '99 and up, headers, Lincoln Mark VIII torque converter, trans cooler, shift kit, lower gears, chip for the computer... AS far a suspension, everything from a police interceptor... |
