92 marquis transmission slipping problem ...
Old Sep 21, 2014 | 05:02 PM
Paul Sharpe's Avatar
Question 92 marquis transmission slipping problem ...
92 100k marquis auto gearbox problem ... slipping into 2nd and 3rd
All fluid and such is fresh and clean and all correct.
I have a slight whining noise from a pump or something from the engine bay and had read about a front gearbox hydraulic pump pressure problem ... but there is no pump to see... that is at having a quick look. is this the problem and how to fix it or ???? any info help much appreciated.
Old Apr 28, 2018 | 01:19 PM
Problem indicates that the Transmission Filter (Motorcraft FT-100) needs replacement.
Transmission filter inside your trans should be changed at every 30,000 miles.
Get the Motorcraft filter, and re-use the ORIGINAL pan gasket -- that requires NO RTV SEALANT !!
I installed a B&M Drain Plug Kit to make future trans filter changes quicker, easier, and with NO MESS to clean up later.
You will need to have 5-6 quarts of transmission fluid to re-fill to proper level -- DO NOT OVER-FILL !!
pooldave1
Mar 8, 2013 07:57 PM
JSanchez830
Jun 28, 2012 06:31 PM
BLenertz
Jan 23, 2011 05:02 PM
New Mercury Owner
Oct 6, 2009 04:44 PM
mady1960
May 22, 2009 04:34 PM
