94 grand marquis headlights flicker on and off
Old Oct 13, 2021 | 08:03 AM
Kwhit440's Avatar
Default 94 grand marquis headlights flicker on and off
My headlights will randomly turn on and off rapidly. It does it worse on high beams. In know the newer cars had thos issue with the LCM but I'm not seeing that my car has one. Could this issue be my daytime running light model under the good.
Old Oct 17, 2021 | 10:34 AM
I had the same issue with the famous 95 MERC restoration.
Fixed the problem with a new aftermarket headlight switch from Amazon.com.
Part # -- REPF 108905 - Head Lamp Switch
The new switch comes with a BLACK faceplate -- Before installing, I swapped the new one with the original faceplate, so it matches the dashboard color perfectly.
Easy job -- take your time and work carefully.
Good Luck !
1995 Grand Marquis Restoration - Mercury Forum - Mercury Enthusiasts Forums
Old Oct 17, 2021 | 10:44 AM
Kwhit440's Avatar
Default Think I have it fixed
I think I have it fixed. Pulled the switch and someone had done some shotty wiring in the factory connector. Replace switch and connector harness. So far so good
Old Oct 17, 2021 | 10:57 AM
Default Heaadlights
Sounds like a winner !!
The '94s & the '95s are nearly identical, so I may be of some help in the future.
Gimme a holler -- any time.
Sleeping Beauty, Rolling Thunder
Galaxy
Oct 17, 2021 10:48 AM
frog_nm
Dec 3, 2007 07:11 PM
spikeyjad
Oct 23, 2007 09:13 PM
bskicrash1
Oct 19, 2007 07:58 AM
herroherror
Jun 3, 2006 12:53 AM
