94 grand marquis headlights flicker on and off
My headlights will randomly turn on and off rapidly. It does it worse on high beams. In know the newer cars had thos issue with the LCM but I'm not seeing that my car has one. Could this issue be my daytime running light model under the good.
I had the same issue with the famous 95 MERC restoration.
Fixed the problem with a new aftermarket headlight switch from Amazon.com. Part # -- REPF 108905 - Head Lamp Switch The new switch comes with a BLACK faceplate -- Before installing, I swapped the new one with the original faceplate, so it matches the dashboard color perfectly. Easy job -- take your time and work carefully. Good Luck ! 1995 Grand Marquis Restoration - Mercury Forum - Mercury Enthusiasts Forums |
Think I have it fixed
I think I have it fixed. Pulled the switch and someone had done some shotty wiring in the factory connector. Replace switch and connector harness. So far so good
Heaadlights
Sounds like a winner !!
The '94s & the '95s are nearly identical, so I may be of some help in the future. Gimme a holler -- any time. https://cimg6.ibsrv.net/gimg/www.mer...2af9a3256a.jpg Sleeping Beauty, Rolling Thunder |
| All times are GMT -5. The time now is 06:58 AM. |
