96 Grand Marquis coolant pissing out
Old Jul 24, 2008 | 09:45 PM
Jason78's Avatar
Hi my name is jason i live in edmonton I''m currently driving a 96 grand marquis 4.6L. Theres a major coolant leak seems to be coming from the rear of the motor although there are traces at the top on the passenger side. the car didn''t over heat and there is no cooant in the pan. I just got the car a few months agoand haven''t had the chance to buy a repair manual. what could this be???
Old Jul 26, 2008 | 02:51 PM
jason sereiko's Avatar
Sometimes these are hard to see when fluid is all over the place. A common problem with the year car you have is the manifold. thecoolant passover is plastic and later versions have the metal crossover because of these always falling apart. Check if it is leaking around there. This is the first place to look. Let me know. You can buy good used ones with the new version "PI manifold" on ebay for cheap
Old Aug 22, 2008 | 07:13 AM
Jason78's Avatar
Thank you very much for this information as it was the problem sooory so long for reply i found manifold for $400 plus tax brand new it took three hours every night for one week and finally i finished. once past wiring and cables it seemed to be relativly easy your canadian friend thanks you very much
Old Aug 22, 2008 | 11:50 AM
no problem.
make sure the vaccum lines are ok. coolant can eat it.a good way to check it is use a propane tank. attatch a rubber hose to the end of the on/off valve. open the tank. start the car. spray the propane around the vaccum lines. if the car seems to run better when it hits a line then you have a bad vac line. the propane will seep into the lines and make a car run better if there is a leak.
Crayfish
Aug 13, 2013 06:16 PM
Project1948
Jun 29, 2012 11:24 PM
dmerc95
Feb 16, 2012 04:02 AM
Shonlo503
Feb 11, 2011 02:51 PM
11teen
May 31, 2009 02:29 AM
