97 Marquis No Flashers, No Highbeams
Old Feb 14, 2008 | 12:18 PM
DKAudio's Avatar
I have a 97 Grand Marquis with 126K. I bought the car used and have had it for 6 months. My high beams and hazards have never worked.
If I push down the button on the steering column for my hazards my blinkers stop working but I don't get any flashing.
If I mess with the lever for my high beams I can sometimes get them to blink but that is it. I'm assuming this is some kind of electrical problem, I am hoping this is common and a cheap fix.
Any ideas?
< =text/>
_uacct = "UA-939292-45";
urchinTracker();
Old Feb 14, 2008 | 02:25 PM
sounds like you signal switch is going bad... also... check all fuses including under the hood
Edited by: 87_Crown_Vic
Old Feb 14, 2008 | 04:03 PM
DKAudio's Avatar
</>Checked all fuses already. How much is a signal switch, hard to install?
Also my headlights are super dim and I have silverstar ultras. I think I read to rub it with rubbing compound because the plastic yellows with time. I assume I do this on the outside of the unit? &lt; =text/&gt; _uacct = "UA-939292-45"; urchinTracker(); </>
< =text/>
urchinTracker();
</>Edited by: DKAudio
Old Feb 14, 2008 | 04:07 PM
correct on cleaning of the exterior of lenses. signal switch isnt that hard... pull column cover off and get to the switch that way. i would disconnect the battery to avoid air bag issues.
Old Feb 14, 2008 | 04:47 PM
DKAudio's Avatar
sounds good, thanks
< =text/>
urchinTracker();
DKAudio
Aug 10, 2009 12:20 PM
Choward
Feb 20, 2009 11:58 AM
