98 mercury gm
Old Aug 19, 2019 | 07:58 AM
Rayy's Avatar
Default 98 mercury gm
Car drives fine. After going 50 miles or so,engine loses power. If I pull over and switch engine off and restart it. It runs normal for anothet 30- 50 miles. Then it does it again.
Any ideas will be appreciated. Thanks
Old Aug 20, 2019 | 09:25 AM
Sounds like fuel starvation --
Change the Fuel Filter.
Part # = Motorcraft FG1114
Add a 20-ounce bottle of Chevron's TECHRON Fuel System Cleaner to a low tank, then fill it up.
The Techron will clean your system of water, varnish, and particles -- and it cleans the fuel injectors, too.
I add a bottle of Techron at every 5,000-mile oil change.
If the problem persists, check the fuel pressure -- you MAY need a new Fuel Pressure Regulator.
Part # = Motorcraft CM4861
Both parts available from RockAuto.com -- best prices, best selection.
The 95 MERC has a Mallory Adjustable Fuel Pressure Regulator -- set at 35 p.s.i. @ 750 rpms.
Old Aug 20, 2019 | 09:42 AM
Rayy's Avatar
Default 98 merc gm
Thanks for the info. I will try your suggestion.
Old Aug 20, 2019 | 10:12 AM
raski's Avatar
I would check for a fuel pump starting to break down by monitoring your fuel pressure. If your fuel regulator has a vacuum line, pull it off, if there is fuel present it is bad and will also make your engine run very rich. If no gas is present it is good. Remember, the fuel pressure regulator is there to keep the pressure from going too high..By restarting it, you are basically repriming the system.Pressure specs for your 98 is anywhere from 30-45 psi at idle.
Old Aug 20, 2019 | 11:48 AM
Rayy's Avatar
Thanks. I will check that.
Old Sep 3, 2019 | 04:22 AM
Rayy's Avatar
Default 98 merc gm
It was the fuel pressure regulator. Drove 700 miles today.
THANK YOU FOR THE INFO.
GREAT HELP.
GREAT FORUM!
Lazasco1
Aug 8, 2023 01:49 PM
stanfordm
Jan 2, 2017 08:18 PM
chrisreed26
May 13, 2011 10:34 PM
MJB DIGITAL
Oct 28, 2009 10:55 PM
Harvest Gold
Oct 9, 2008 08:06 AM
