Alignment on 2000 Mercury
Good afternoon to all:
This is the problem I am having. My 2000 Mercury Grand Marquis was pulling to the right just a little. I had it aligned at Sears and it was pulling to the right a lot, plus the steering wheel was not straight. I have carried it back 3 times and they say the car is aligned. It has new tires on it and I have had them checked and no problems there. Has anyone had a problem like this (Sears did replace the idler arm) - could Sears machine be messed up? |
i would question them when the last time it was calibrated... a shop i worked at caused cars to slightly pull to the left... we learned the machine was off and adjusted with steering wheel turned slightly to compensate... finally got the machine calibrated so no more compensating...
Originally Posted by 87_Crown_Vic
(Post 15558)
(Post 15558)
If you are going 30 MPH it seems to be ok, at 65 pulls to right and steeing wheel not quite straight. With everyone telling me it is alright, not sure what to do now, but I know there is something wrong. (also had the tires checked and they were ok). |
see if you could flip tires ... put the pass. front on driver front and driver front to passenger front...
(Post 15572)
Hi,
I've had the same issue on my 2002, it turned out that the ball joints were worn. I had them replaced en the problem was gone. good luck, grts |
Originally Posted by guido401
(Post 15589)
Hi,
many places dont check front end parts correctly... you need to use a floor jack and jack up the front corners by lifting at the lower control arms... when up that way, grab top of tire and bottom and push top in while pulling bottom out and shake it that way... then grab tire and do it side to side... up and down will tell you ball joints or bearings loose and side to side will be tie rods or bearings... need to have helper and have them shake it while looking under the car
(Post 15591)
| All times are GMT -5. The time now is 08:34 AM. |
