bulb replacement
Do I have to remove the headlight assembly in order to replace the parking light? It is A 1996 MGM. Rich W
Bulb Replacement
Originally Posted by RichW
(Post 22949)
Your '96 Marquis has three (3) lights on each side of your front end: !. - Headlight. 2. - Parking Light. 3. - Marker/Cornering Light. In the enclosed photo, you will see that the Parking Light is directly BELOW the Headlight. It is not necessary to remove any other lights in order to replace the Parking Light Bulb. The bulb is changed by removing the 2 Phillips-head screws that hold the lens in place. I recommend switching from the standard bulbs to the LED type, as the LEDs make a whiter lite that is visible from a greater distance. When on trips, I run with Parking Lights "ON" -- the LEDs in the Parking Lights make for EXCELLENT running lights, and are a great safety feature. Changing the bulbs in the Marker/Cornering lights is more difficult. You may have to remove the plastic panel that has the emissions stickers stuck on to it. In any case, you should NOT have to remove a headlight to gain access to the Parking Light Bulbs. Lemme know how you make out with the bulb change !! https://cimg5.ibsrv.net/gimg/www.mer...4410eddba9.jpg Classic Style -- Modern Comfort |
I can recommend you replace your old parking light and install LED. When it comes to replacing old incandescent bulbs with LEDs, you have to remove the headlight assembly. best headlight bulbs - here you can read more about it and chose the right one for your A 1996 MGM.
LED Lights
The 95 MERC has had ALL headlight, tail light, and parking light bulbs replaced with LEDs.
The parking and tail light bulbs need to have resistors installed at each light housing to avoid hyper-flashing. Easy job that yields excellent results, https://cimg8.ibsrv.net/gimg/www.mer...5f8e05b7b1.jpg Headlights = Halogen Bulb on Driver's Side. LED Bulb on Passenger's Side. LED Parking Lights. |
It depends on what exactly happened to her. As I understand it, the damage was not affected by any more problems with electronics. In this case, it is not necessary to change the headlight itself. On the contrary, I was not so lucky and burned one network of electrical wires in the house, so I had to pay a lot of money to have it all replaced. I advise you not to play with electricity and generally trust it all to professionals. In the house, I now use , and so far I have no problems with this
