A/C not working
I have a 96 grand marquis and the I have the digital ac control panel. And for some reason it will not switch from heat when I try to turn the ac on. Can anyone give me advise on this?? I have even put it on 60 max ac and still all heat.
Sounds like a blend door problem.
Air cooling which can do numerous stuff can provide more chillness
The air conditioning in my Grand Marquis is no longer functional, either (though, mine is for a different reason: I have multiple leaks in the coolant lines and I believe that the compressor is shot.).
However, in your case, it could be a few problems that are preventing you from using the air conditioning. I shall list these possibilities below:
I hope any one of these answers helps you out. I know how frustrating that a broken A/C system can be (I still have yet to rectify MY system)! Prices to repair this sort of stuff all depends on what's broken and who you take it to. Obviously, if you take it to a dealership, you will be charged a premium, versus if you take it to a local or independent mechanic. Also, here are a few links to some videos on YouTube which can help you further identify any issues you may have. The man's name is Scotty Kilmer - and he has been a mechanic for the past 40+ years now, and has LOADS of experience dealing with this stuff. "Fixing a Car Air Conditioner that Blows Hot Air" - http://www.youtube.com/watch?v=I5xfV...feature=relmfu "How to Replace Your AC Compressor" - (This one shows you how to tell if your compressor is bad) http://www.youtube.com/watch?v=9ULci...feature=relmfu Hope this helps! |
Mode door...
It's called the 'mode door actuator', & it needs replacing. It probably has a worn gear which keeps the door (under the dash above the floor 'hump') from switching from heat to AC. Will cost app. $300 as the dash will have to be removed, the part will cost about $4 but worth about 65 cents.
I agree with the post sthat the Blend Door, or Actuator is most likely your cause of inoperable AC.
As others have posted, this is a $16 part that costs $300 to replace. Have a nice day, Bill |
It probably has a worn gear which keeps the door from switching from heat to AC.
I should be for the blend door problem, you may have to replace it.
