calibrate speed (rear change)
Old Oct 24, 2010 | 12:36 PM
rsrace's Avatar
Default calibrate speed (rear change)
I am getting conflicting information on how to change the speedometer reading. My car had a 2.73 rear end which had rusted spring perches (it came from the salt belt where it had few miles but lots of salt).
I changed out the entire rear end for one with a 3.27 ratio. Now, of course, the speedometer is reading about 20% too fast. Some have suggested that there is a gear in the transmission on the VSS that I can change but I am unable to find sources for multiple gears. Some have suggested that the change is done with a programmer - but mine (OBD-2) reads the VSS and calibrates speed by the VSS signal times time...so there is no rear ratio, tire size, etc. to input.
Does anyone know how to calibrate the speed/mileage? If it is a plastic gear like on my old Ford car, where can I get them?
Thanks in advance,
Randy
youwantfkme
Feb 9, 2009 10:38 PM
merry
Jan 24, 2009 11:38 AM
youwantfkme
Jan 21, 2009 01:01 PM
Cougar94
Dec 12, 2008 04:48 PM
MJND1990
Feb 4, 2008 06:57 PM
