changed spark plugs, now stalls?
Old Dec 15, 2008 | 12:59 PM
srch4aresn's Avatar
my car started stalling at red lights occasionally, so i decided to change the spark plugs, along with the wires.
ill start the car and let it run for a few mins but as soon as i put it in drive, about 5-10 seconds later the check engine light along with oil light and battery light comes on and the car stalls, but the electrical doesn''t shut off.
right before this happened, this is what happened:
changed positive battery terminal
changed spark plugs (didn''t gap them) and wires
Old Dec 15, 2008 | 03:12 PM
if they are normal plugs, you HAVE to gap them. Otherwise you WILL have this problem. You should also check the battery terminal crimps to make sure they are really good and tight to the wires. if there is the slightest bit of slack on the wires (even if they don''t move when you wiggle them) you will not be getting good contact.
also double check that the wires are snapped in place at each end. if the wires are not fully connected, you will have misfires.
mustangdave
Sep 1, 2017 12:35 PM
92Mercury
Jan 4, 2008 03:12 PM
jinroh
Feb 3, 2007 01:26 AM
virtualdemo
May 12, 2006 12:29 PM
chueco
Sep 14, 2005 07:02 PM
