check engine light on
Old Dec 28, 2006 | 12:33 AM
damercga's Avatar
I have a 2001 gm ls,I had an amp installed at a local shop and the dummy screwed a hole in the gas tank. Since then i've had the tank replaced but the check engine light comes onevery3 days or so. I had the code read, its a code 42 they keep telling me its the gas cap so i bought a new one and the light still comes on any ideas ?
Old Dec 31, 2006 | 05:24 PM
sheebeehuh's Avatar
If the gas tank is not sealed (air tight essentially) you get that code. The gas cap is the most common culprit. Since your tank has been replaced you probably have a vapor leak somewhere else causing the code.
Who replaced the tank? The dealer?
214shaft
Jan 3, 2011 11:21 PM
olds97_lss
Jul 6, 2008 02:12 PM
geri
Sep 5, 2007 05:14 PM
geri
Sep 4, 2007 08:18 PM
Chris
Apr 24, 2005 01:39 PM
