cruise control on the blink
Old Jul 21, 2011 | 05:50 PM
Marquis03's Avatar
Default cruise control on the blink
Hello All, this is my first time using the forum. I have an '03 Marquis, the cruise control was intermittantly working and now it doesn't work at all. Any ideaS??
Old Jul 25, 2011 | 01:54 PM
Tripper511's Avatar
Could be a circuit. Check your fuses and make sure they're okay.
Old Mar 22, 2023 | 10:12 AM
flackbait's Avatar
Wink
Check for corrosion in both fuse blocks . Do other accessories on the same circuit still work? I would check the electrical ground assigned to this circuit. In fact, I would check all body grounds. Has the car been in an accident? Visually check the throttle connections. Is there a vacuum hose missing or decayed? Does everything move without binding? Does the horn work. I had a Ford Escort with a bad horn circuit ground and after I fixed that, the cruise control started working.
MGM46
May 31, 2023 02:08 AM
Beast1
Mar 24, 2023 09:38 PM
Infinity RC
Jun 13, 2022 09:36 AM
usair
Aug 6, 2010 12:18 AM
FTLOSM
Jun 26, 2008 05:12 PM
