F***KING Vandals Stole My Hood Ornament Again!!
Old Oct 14, 2009 | 04:41 PM
89GrandMarquis's Avatar
Default F***KING Vandals Stole My Hood Ornament Again!!
Hey guys this is the 3rd time that some one had nicked the ornament from my hood. I got the car without one so i got another at a scrap yard and just made it stay with some wire but how do i install one the proper way do i take out the grill?? thanks
Old Oct 14, 2009 | 07:51 PM
there's a nut underneath holding it all together. There should be a spring that the ornament clips to (down through and around the other end actually). I think removing the nut will allow it all to come up and out of the front cowl. At least that's the way it looks on my 88 MGM.
Old Oct 15, 2009 | 11:37 AM
you are correct... under the fiberglass where the hood ornament is, there is a tin nut. i use pliers since it isnt hard to twist off and loosen. after the nut is off, the whole hood ornament assembly comes right out.
Old Oct 15, 2009 | 11:43 AM
great thanks at least it will be harder for them to pull it out then just holding it with wire
Old Oct 15, 2009 | 12:52 PM
kwolfeman91's Avatar
cant believe some one would steal a hood ornament...
Old Oct 15, 2009 | 01:32 PM
I can't believe someone would steal the dullard of a hood ornament that's on our cars.
Old Oct 16, 2009 | 03:59 AM
i have the one from the 89' grand marquis and the ornament from the 85' MGM that looks like the lincoln symbol and the one from the old LTD's thats rectangular with a triangle in it but they dont fit in the hole quite right.
Old Oct 16, 2009 | 09:49 AM
mine dont have one....
Old Oct 16, 2009 | 03:09 PM
  #9
You'd probably have to resize the hole to fit ornaments from other body styles.
Old Oct 27, 2009 | 11:16 PM
  #10
MJB DIGITAL's Avatar
Default feeling devilish?
run some current through it from the battery! see how the jerks like that. 8)
