-   -   fogs on an 06 (https://www.mercuryforum.com/forum/grand-marquis-14/fogs-n-06-a-1662/)
olds97_lss May 16, 2008 07:49 PM
Yeah, I dig the tint... I need to get that done to mine. Hopefully soon.
20marquis07 May 16, 2008 08:11 PM
thanks man...looks like grandpa without tint ;)
Duffy May 17, 2008 06:22 AM
Here's mine with fogs added:
[img]uploads/Duffy/mgm_fogs.jpg[/img]
20marquis07 May 17, 2008 09:18 AM
i like that..they do look really good:)
Now i gotta get to the car wash, clean mine up and shine my tires....i had to drive in the rain 3 times last week and they look bad [img]smileys/smiley19.gif[/img] Hate it when my tires aren't black as my windows hahah
pdh_71 May 22, 2008 11:04 PM
Originally Posted by Duffy
I think there is a law that requires fogs off on high beams (?).
YES! (and no a little). There is a law, but it doesn't specifically apply to the type of lamp (fog) but the number of lamps.
The law is no more than 4 beam lights (fogs, lows, highs, not parking or corning lamps).
lo - 2 lamps
lo with fogs - 4 lamps (2 low 2 fog)
hi - 4 lamps (2 hi 2 low)
hi with fog - 6 lamps (2 low 2 hi 2 fog) - violates light law
so now all car manufacturers have added relays in order to shut off the fogs when the hi-beams come on.
On my '96 Intrepid if you held the controller without clicking it into position you could run all six, however, my '04 300M's relay was installed at the lamps not the switch, so once electricity reached the hi-beams it killed the fogs, even if you didn't pull the controller all the way.
Edited by: pdh_71
20marquis07 May 23, 2008 04:40 AM
i saw an 08 smokestone just like mine ysterday but it had the plain rims on it...looks cheap looking IMO without the chrome wheels
Duffy May 24, 2008 09:21 AM
Set of fogs on eBay. Shipping is very high...
20marquis07 May 24, 2008 03:42 PM
since schools out no spare change til fall now...lol guess it'll have to wait, and with gas at 4 bucks a pop thats killing my spare spending! :(
06GM Nov 23, 2013 11:53 PM
Pending Foglight install on my 06 LS
Originally Posted by Duffy (Post 5310)
Yes. Mine came without fogs. I installed them and working fine. They show up on eBay often, so check there for both sides. It may take a month or two to get a pair. Just remove the black out panels and install the fog with same screws. I installed them as if they were factory installed. First, replace the light switch with the fog light option. You can access two wires under the dash for relay and light module control. You really need a wiring diagram to understand where and why you connect the wires. Mounted a relay (Wal-Mart fog light relay) near the battery junction box under hood where all wires met -light switch, light module signal, and fog power wiring. It is simple to do once you understand the wiring. Using the factory hook up, the fogs go off on high beam. If just using a separate switch fogs are on all times. I think there is a law that requires fogs off on high beams (?).
I could email you a page from the wiring diagram manual to show how I did it. Tom
Hi Tom,
Any chance of emailing me a page from the wiring diagram manual as I'm getting ready to obtain the parts to do this? Cheers! John
