grand marquis shakes when it shifts
Old Mar 5, 2011 | 11:04 PM
  #11
Bulldozer's Avatar
Those responding to this thread, do you realize it is 6 months old?
Old Mar 5, 2011 | 11:17 PM
  #12
rreitz's Avatar
Good point. It's helpful to post what the solution was when found to prevent needless posts and to educate others on the solution.
Old Mar 7, 2011 | 01:26 AM
  #13
pancholin's Avatar
I second that ''rreitz''. 6 months or 1 year, as long as the thread is open it does not hurt to keep posting possible solutions. If original poster does not let us (forum users) know what the solution was then we would think the problem still exist.
Old Mar 8, 2011 | 02:20 AM
  #14
TheMaskman's Avatar
the engine just boggs down and has no power if your on the throttle more then 50%. light throttle there are no problems and it runs fine. heavy throttle and you lose everything. If original poster does not let us (forum users) know what the solution was then we would think the problem still exist.
Old Mar 10, 2011 | 12:52 PM
  #15
pancholin's Avatar
TheMaskman...... was that a question? or just fooling around by repeating my words?
Old Mar 29, 2011 | 09:28 PM
  #16
billccm's Avatar
There has been several TSB that address 'tranmission shift shudder', and it is usually caused by the torque converter slippage.
A basic pan drop, fluid drain, filter replacement, and top off with Mercon should fix your problem. Personally, I recommend staying away from FLUSH machines. These cause particles and dirt to blow into areas that could cause future trans damage.
Let us know how you make out, Bill
Old Feb 16, 2022 | 02:10 AM
  #17
jjuules70's Avatar
96RedTracer
Feb 3, 2015 08:17 PM
kosc0041
Nov 26, 2014 02:01 PM
Henrythe12th
Mar 27, 2013 01:30 PM
jason sereiko
May 22, 2008 09:36 PM
Texas_MGM
Feb 4, 2008 02:18 PM
