trans shifts hard after adding 2 quarts
Old May 21, 2008 | 05:04 PM
jason sereiko's Avatar
I have a question. My 1998 MGM transwas 2 quarts low. It was taking a second to go into gear. That was fixed after adding the fluid, now it is shifting hard like a shift kit. The thing is when it was low on fluid it shifted perfect when driving except for the second it took to go into gear when I take it out of park. Now the darn thing is shifting like i put in a shift kit[img]smileys/smiley3.gif[/img]has this ever happened to anyone? and will it go away. Should I change all the trans fluid or give it some time? The car has 269K on it but it runs great. I think the car at one time had a motor and trans replacement because it runs very well for 269K. I don not want to blow the trans. Please help if you have had this happen before
Old May 22, 2008 | 12:49 PM
it is better for it to shift harder as opposed to soft shifting. think of a manual transmission... would you let the clutch slip its way into gear and burn the clutch or let it shift a little stiffer so to not burn the clutch?
Old May 22, 2008 | 09:36 PM
you got a point.
Stworsen
Sep 25, 2014 07:57 PM
ealfuth
Jun 15, 2009 07:33 PM
olds97_lss
Jun 13, 2008 03:28 PM
Texas_MGM
Feb 4, 2008 02:18 PM
srch4aresn
Jun 4, 2007 08:00 AM
