Headlight removal plus more questions
Old Jul 27, 2008 | 10:40 PM
hanyou_kimura's Avatar
Old Jul 28, 2008 | 02:41 PM
Seriously, wtf is wrong with this site?
Old Jul 30, 2008 | 05:21 AM
Duffy's Avatar
I think the keeper of this never reads our complaints. He has never responded to any complaint that I have seen posted. Maybe this is a ghost site.
Old Jul 30, 2008 | 06:57 AM
conan312's Avatar
What year is it and mileage?
Old Jul 30, 2008 | 09:16 AM
Old Jul 30, 2008 | 10:16 PM
jason sereiko's Avatar
replace the switch for the door before replacing the motor. just switch out one that works on a different door and see if the window starts. you can also jump out the switches. also try to hit the motor with a hammer. this works sometimes.
Old Jul 30, 2008 | 10:24 PM
<DIV>pop off the center cap or twist it off. under it should be a screwlock</DIV>
<DIV>this holds on the hubs.</DIV>
<DIV></DIV>
<DIV>is it burning oil or does it have blow by. is the exhaust smokeblue </DIV>
<DIV>color?
</DIV>
<DIV>the motors for the windows can be a pain. if you take your time they are not that bad. it is good practice on a junk yard car. you might need a drill to drill out the rivits for the motor. I would really check all the fuses and then the switch for the window first. then take off the panel and tap it with a hammer. </DIV>
Old Jul 31, 2008 | 09:17 AM
At the very the driver''s regulator is shot. It make horrible grinding sounds when you try to move it up or down, and dones''t really go anywhere.
The other 2 windows move slightly then stop,a nd won''t go back up. So I''m thinking motor.
There''s blue smoke from the exhaust. Normally it''s not much, but when the car had issues going in reverse it would belch out a ton of blue smoke.
OMG, did tually fix the posting problem?!
Old Jul 31, 2008 | 02:45 PM
  #9
Is t here some kind of special key to unlock the hubcaps? There''s a set in the junkyard I want to get.
Old Jul 31, 2008 | 02:57 PM
  #10
no not for those, a screwdriver should do the trick. if not hammer on a smaller socket over the lock if there is one. This will fit very tight ovet it and them you can loosen it with a ratchet. Otherwise a regular screwdriver should get it if you pop off the center cap. however you will need the tripod piece that is fastned under the lugnuts to put these on your car. if you just put the caps on without it they will fall off over the first bump
onewheelpeel
Dec 17, 2008 10:06 AM
unit731
Sep 11, 2008 10:32 AM
RobG
Mar 24, 2008 08:51 AM
cougarowner
Sep 20, 2007 12:17 AM
burnindesirez02
Mar 29, 2007 01:46 PM
