Help with cylender 6 ignition failure code
Old Jul 16, 2020 | 02:54 PM
TheLandauKid's Avatar
Default Help with cylender 6 ignition failure code
Hi everyone,
I recently bought a 2004 GM ultimate edition and everything was fine. I left it sit for 12 days while I was on vacation and when I came home and started it the engine light was on and it was running rough. I grabbed my code reader and it said secondary ignition fault ( I forget the code number but it was the code for cylinder 6). I put new coil packs and spark plugs on it today but that didn’t solve the problem. It only does it intermittently and sometimes it does it worse than other times and sometimes not at all. Whenever it is running rough the ac compressor clutch kicks out also. Anyone have any ideas? Thanks
Old Jul 17, 2020 | 05:22 AM
raski's Avatar
Since it started misfiring after it sat for 12 days, you might want to look for rodent chomp marks on the wiring which might be shorting.
roy1
Aug 2, 2020 05:25 AM
Joedubbs27
Oct 10, 2015 03:38 PM
pancholin
Jun 10, 2011 03:33 PM
mcgilla30
Apr 25, 2011 06:46 PM
dlonna
Jun 20, 2010 07:02 PM
