How Do You Flush the Cooling System?
Old May 9, 2015 | 04:00 PM
Bimmer's Avatar
Default How Do You Flush the Cooling System?
I did a search and came up empty. We have a 1998 Marquis with 4.6L engine. This car has sat for 10 years. Initially the intake cracked and my wife (I didn't know her then) knew enough to shut it down when it began to overheat. Took it to a shop and they confirm the intake was cracked. Fast-forward to 2009. My wife moved from Houston, Tx here to Missouri so we could start a life together. I found a retrofit-kit on Ebay for $200. We installed it and then it wouldn't get fuel . I found the pump wasn't activating at all so I replaced that sucker. Then I got hurt and couldn't do much on it so it sat. Yesterday, I finally got it started and it runs a little rough but no overheating but upon checking the coolant it needs to be flushed and replenished.
I bought a Prestone Flush N Fill kit only to find out that the radiation has no radiator cap, just the coolant bottle. So I went to YouTube and they were no help as all those viewed have a radiator cap.
So, has ANYONE flushed their system and if so, how did you do it?
Thanks Folks!
*** Going to go drain the oil and replace the oil and filter.
Old Jun 1, 2015 | 11:44 PM
MississippiMark's Avatar
Chilton's (1-33) says that you remove the cap from the expansion tank on 1992 and later models (after making sure the engine is completely cool, of course).
ansky926
Jul 2, 2017 11:38 AM
carid
Nov 20, 2014 05:09 AM
drakosdarklata
Nov 26, 2010 11:05 PM
ClintsCougar
Mar 24, 2009 11:42 PM
asshatmagee3
Mar 14, 2008 08:25 PM
