i need help with air ride!!!
wat is the best combo of airride bags all around, air struts in front and bags in the back or, airstruts in the front and air shocks in back. if anyone can hellp u can email me @bigg_daddy6949@yahoo.com
< =text/>
_uacct = "UA-939292-45";
urchinTracker();
the car has shocks all the way around, not struts. how do you plan on raising and lowering it? if you plan on raising it and not controlling from inside car, you could go with air shocks you can use a standard compressor to raise to height and drive. or release air from the shocks like a tire. not real sure how you want your setup
thanx 87_crown_vic i didnt ikno if it had shock or struts in the front so ill go wit a 5 gallon air tank and bags do u kno how hard it is to install bags in the front?
< =text/>
urchinTracker();
Youll have SOME extra room, as you wont have the spring anymore, but you have to keep the strutt AND make room for the bag... it wont be bad, fab up some custom mounts, backs should be fairly easy... we'll have to check it out someday... but the kits from our sponsor come with mount plates for the bags, might be able just to mod them and get them to fit, then weld em up...
