ID Handing package version 2000 Grand Marquis LS??
How to ID the handing package on a 2000 Grand Marquis LS? Big thanks, the front end kit is different for that version .
Get the Handling Package Kit if you want better-than-stock handling.
Either kit will fit your Merc. RockAuto has a Moog Kit for a good price. I restored/modified the entire front suspension of the 95 MERC -- Springs, spring isolators, shocks, ball joints, hubs, control arms, tie rod ends, idler arm, and end links. All suspension bushings were replaced with Energy Suspension Urethane Bushings. All MOOG Problem-Solver greasable joints, lubed with LUCAS X-Tra Heavy-Duty grease. The 95 MERC is set up for long-distance, high-speed cruising and frequent mountain driving. |
Originally Posted by 95 MERC
(Post 22400)
The factory duals would indicate a Performance Package.
The factory dual exhausts are worth about 20 horsepower over the single exhaust, according to Ford. I have no idea as to what is included in your Performance Package -- mebbe the differential gears are shorter. The standard ratio is 2.73 : 1 5,000-lb. Trailer-Tow Package (no longer available) is 3.75: 1 |
| All times are GMT -5. The time now is 07:44 AM. |
