ignition coil?
Old Nov 8, 2008 | 10:36 AM
deadpirahna's Avatar
My car will run with a rough idle, then stall after a while. If i drive it and turn it off, it may take up to 4 hours before it starts again. Could this be the ignition coil or packing? It is a 1992 grand marquis ls with only 73K milesEdited by: deadpirahna
Old Nov 8, 2008 | 05:50 PM
yeah... probably the coil... do check the plugs and wires while you''re at it. also if it''s a distributor system, check the cap and rotor for wear. it could also be the ingnition module. If it''s a distributorless system, it could be the coil packs (should be one mounted on each valve cover) or the ECM. I would think that if it''s the latter 2, it would be giving codes. You may want to see of you can get the computer read and see if there''s any codes that may help diagnose this.
Old Nov 10, 2008 | 02:57 AM
conan312's Avatar
Have you checked Ford''s ever reliable ingnition module? My Ranger did the same until I changed the mod. and it runs fine now.
maxfax3
Dec 6, 2008 12:43 AM
forkliftrman
Mar 4, 2008 10:12 AM
mythos07
Nov 28, 2007 01:01 AM
SableCat
Sep 10, 2005 08:12 PM
teskey3
Jan 23, 2005 02:12 PM
