noise power steering pump
Old Jul 6, 2007 | 08:26 PM
5jordan's Avatar
my 98 grand marquis just started making a squeeking noise when the wheels are turning. it sounds like it is coming from the pump. i checked the fluid and it smells funny not like new fluid does. i am wondering if there is a drain on the pump that the fluid can be drained and new fluid replaced? or is the pump gone and that is what is making the fluid smell? any ideas or fixes?
thank you for reading this
Old Jul 10, 2007 | 06:46 AM
92Mercury's Avatar
Well, you might want to consider that the fluid is 9 years old.
Yes, you can change it, but the system has to be bleeding afterwards, or your pump will run dry, and that will kill it.
I had the same issue, I had the fluid changed ($55 at the dealership), and thus they told me it could take a while to notice any change if it helps, the noise was gone right away, and never came back.
Here's the details about the pump:
[img]uploads/92Mercury/0900823d8017421c.gif[/img]
Old Jul 10, 2007 | 07:45 PM
5jordan's Avatar
thanks for info, that sounds perfectly logical. i will have my mechanic change the fluid and bleed the system. thanks for the reply
Old Jul 16, 2007 | 12:03 PM
92Mercury's Avatar
You're more than welcome.
I know put a little over 750 miles on mine, and everything is still fine, quiet, the way it's suppose to be.
Let us know the outcome. Would be interesting to see how it went. Good luck.
Greetings.
Old Jun 1, 2008 | 10:36 PM
jason sereiko's Avatar
how do you bleed it?
kleuch48
May 10, 2011 10:43 PM
hdy443
Nov 25, 2010 10:49 PM
slymer
May 31, 2009 03:17 PM
ClintsCougar
Mar 24, 2009 11:42 PM
DetroitDublin
Aug 25, 2008 07:50 PM
