slymer |
08-02-2009 10:23 PM |
if the gears are not missing any teeth, then the motor isn't the problem. But just to make sure, plug it back in (just electrically) and make sure it turns when the window switch is pressed. next, check the gearing on the regulator to make sure it's not stripped. If it is, there's your problem and the regulator needs to be replaced. if the cables are not connected to the regulator (top or bottom) then it needs to be replaced. if it's the older angled/sliding X-bar, you'll need to find out what part is slipping and replace the rivets/bolts or the entire regulator.
