REMOTE CONTROL
Old Oct 17, 2007 | 07:32 AM
coupe's Avatar
i get a new transmitter for the remote control. how can i programmed it?
Old Oct 18, 2007 | 09:08 AM
coupe's Avatar
i find it out, only with the Keypad on the door. But, it doesn´t work, i habe this trouble-code:
B1525 Keyless Entry Circuit Short To Battery
what meen´s that and what can i do about it?
</pre>
Old Oct 19, 2007 | 08:45 AM
92Mercury's Avatar
Probier's mal mit vernünftiger Vorstellung in der Rubrik "Neue Mitglieder".
Und ohne Angabe von Baujahr, Typ und Modell kannst Du lange auf Hilfe warten. Wir sind keine Hellseher.
Greetings!
Old Oct 22, 2007 | 01:36 PM
coupe's Avatar
Mercury Grand Marquis 1996 4.6
Old Oct 22, 2007 | 03:49 PM
92Mercury's Avatar
Much better. Cause they changed programming features late in 1995. Sometimes it's the same, sometimes it's different. Ford, oh well.
Am not sure about this model year, but before that, keypad on the door did notmeanthat you have a remote transmitter. As a matter of fact, on the '92 models only the keypad was available, no remote transmitter at all.
Anyhow, you error code indicates a short ('nen kurzen, Kurzschluss). Easiest fix is taking the keypad off and clean the contacts. Eventually, throughout all the years, water and particles found their way inside and can cause all kinds of issues.
If that doesn't fit it, the search will start. But first we would need if and what it is doing.
Greetings!Edited by: 92Mercury
Old Oct 23, 2007 | 02:17 AM
coupe's Avatar
okay, thx! i will try that
Old Oct 23, 2007 | 09:56 AM
92Mercury's Avatar
Here's the manufacturers article on how to do program the system:
A03-18-1RemoteKeylessEntry.zip
It's a PDF file, but the forum does not allow upload of that kind of file.
Greetings!
Old Oct 23, 2007 | 11:39 AM
coupe's Avatar
wow, thank you
Old Oct 23, 2007 | 12:39 PM
  #9
92Mercury's Avatar
Use the search function. There is a post under General Tech Help, which shows the programming for all kinds of Ford/Lincoln/Mercury vehicles.
Greetings!
MercAdvisor
Aug 17, 2009 10:44 PM
PTLANDOLL
Jan 5, 2009 07:46 PM
Blake604
Sep 20, 2008 11:08 PM
stumped
Apr 21, 2005 03:02 PM
beech
Apr 10, 2005 06:06 PM
