Rushing water behind passenger dash
Old Jan 16, 2020 | 12:13 AM
Evan1234's Avatar
Default Rushing water behind passenger dash
1998 GM LS 131k miles
I sometimes hear rushing water from behind the passenger side dash when making turns or going over speed bumps. AC/heat work great. Is this air in my heater core? I cant seem to bleed any air out by opening the coolant reservoir tank and letting the car heat up. Is this okay to let be? Ive had this sound for a while without any issues. Thanks
Old Jan 19, 2020 | 07:33 AM
Tyler Harris's Avatar
Check the cabin air filter? Mine is located on passenger side and they can potentially let water in.
Old Aug 17, 2020 | 06:44 PM
Mercury Grand Marquis's Avatar
The water is under your carpet. You need to let it out using a plug in the backseat passenger footwell. You'll have to pull up the carpet. First you'll need to remove the back seat, use your knee to push against the seat while simultaneously pulling upwards (this should not take very much force). Then pull the carpet up and find the plug, it should be in the corner. The water in my Marquis came from the cowl drain. The seal had deteriorated allowing water to flow backwards behind the firewall and under the carpet.
DD50
Jun 7, 2023 04:16 AM
zoman1719
Feb 23, 2015 03:47 AM
markury
Jul 28, 2014 08:37 PM
srch4aresn
Apr 30, 2010 07:06 AM
Bigfoot
Jan 3, 2007 10:24 AM
