-   -   shift cable (https://www.mercuryforum.com/forum/grand-marquis-14/shift-cable-6116/)
Barney Jun 27, 2012 08:29 AM
shift cable
My 1992 grand marquis went from bad to worse but no body could tell me what may be problem@#$%% After examining the transmission end I found the cable was moving very easily with the lever in park and the key out when removed from transmission?? I then took off the panels below steering wheel and found that one screw had fallen out of the shift assembly and the other was ready to fall out. I'm in the process of adding a STAR washer and some locktite to the screws and using a #30 torx bit torque them back this should fix my shift problem. What upsets me is the lack of information in the Haynes and the Chiltons manuals as they mention NOTHING about the end inside the car.
Barney Jun 27, 2012 09:28 AM
That fixed my sift problem!!! can actually feel the position detentes going from position to next position. How come neither manual tells this fix??
WOW! feel like Willie "back on the road again"
