Spark Plug Toque
Old Nov 10, 2009 | 12:31 PM
Brokwing's Avatar
Default Spark Plug Toque
Hello every body Im new to this forum I have a 97 MGM with 94000 mi and would like to replace my spark plugs & wires and I had been looking on this forum about the spark plugs but no toque specks.I also see that it is good to use the antiseze on the plug to.The plugs I would like to use is the Autolite APP104 Dub Plm is that the plug that you would use and Im looking at the Motorcraft wire set is that what you would go with.Please help Brokwing
Old Nov 10, 2009 | 06:11 PM
I replaced mine with regular autolite resistor plugs. with a stock engine, you should run stock style plugs unless you're planning on upgrading more than just the bog standard stuff (fresh air intake and dual exhaust). as for torque specs, I don't think I've ever check the specs. I just make them good and snug. Typically it's a quarter turn past snug.
Old Nov 10, 2009 | 10:30 PM
billccm's Avatar
I recall 10 to 13 ft lbs as the spark plug torque spec, but I caution using that spec with anti sieze compound.
I recommend using anti sieze, but a very small amount. I think I used 7 ft lbs of torque when I did this job on my old Crown Vic.
AutoLite double plat plugs are very good for the 4.6l V8.
Let us know how you make out! Take care, Bill
Old Nov 10, 2009 | 10:57 PM
billccm's Avatar
OK, I just looked up the spec for spark plug torque, and it is listed at 15 ft lbs 'typical'. I think with anti sieze you could use 10 ft lbs and be fine.
Good Luck, Bill
Brokwing's Avatar
Thanks for the good information that helped me out alot I will keep you informed.Brokwing
Terry
Feb 17, 2019 11:26 AM
Sparkplugs.com
Sep 1, 2017 03:22 PM
Smokefan
Apr 24, 2009 07:55 PM
andrew65
Jan 24, 2009 05:53 PM
gordoj52
May 9, 2007 03:43 PM
