-   -   Spark Plug Toque (https://www.mercuryforum.com/forum/grand-marquis-14/spark-plug-toque-3888/)
Brokwing Nov 10, 2009 12:31 PM
Spark Plug Toque
Hello every body Im new to this forum I have a 97 MGM with 94000 mi and would like to replace my spark plugs & wires and I had been looking on this forum about the spark plugs but no toque specks.I also see that it is good to use the antiseze on the plug to.The plugs I would like to use is the Autolite APP104 Dub Plm is that the plug that you would use and Im looking at the Motorcraft wire set is that what you would go with.Please help Brokwing:rolleyes:
slymer Nov 10, 2009 06:11 PM
I replaced mine with regular autolite resistor plugs. with a stock engine, you should run stock style plugs unless you're planning on upgrading more than just the bog standard stuff (fresh air intake and dual exhaust). as for torque specs, I don't think I've ever check the specs. I just make them good and snug. Typically it's a quarter turn past snug.
billccm Nov 10, 2009 10:30 PM
I recall 10 to 13 ft lbs as the spark plug torque spec, but I caution using that spec with anti sieze compound.
I recommend using anti sieze, but a very small amount. I think I used 7 ft lbs of torque when I did this job on my old Crown Vic.
AutoLite double plat plugs are very good for the 4.6l V8.
Let us know how you make out! Take care, Bill
billccm Nov 10, 2009 10:57 PM
OK, I just looked up the spec for spark plug torque, and it is listed at 15 ft lbs 'typical'. I think with anti sieze you could use 10 ft lbs and be fine.
Good Luck, Bill
Brokwing Nov 10, 2009 10:57 PM
Thanks for the good information that helped me out alot I will keep you informed.Brokwing
