Spark Plug Wire Routing
Old Nov 18, 2009 | 01:52 PM
Brokwing's Avatar
Default Spark Plug Wire Routing
Hello I had been looking for the spark plug wire routing on the internet for a 1997 MGM with a 4.6L would someone be able to help with that.Thanks Brokwing
Old Nov 18, 2009 | 05:56 PM
check these diagrams:
http://www.p71interceptor.com/firingorder/
I can't seem to find a diagram pointing to the order on the packs themselves (which seems like it would be a very necessary bit of info)
Old Nov 18, 2009 | 06:20 PM
went and looked at my wife's 93. Should be the same order.
Here's a text based diagram (as if you were looking down at the engine from the cab area)
..____.......____
2|O O|4..5|O O|6
8|O O|7..3|O O|1
..__..........__
5|O|........|O|1
6|O|........|O|2
7|O|........|O|3
8|O|........|O|4
Old Nov 18, 2009 | 06:30 PM
Brokwing's Avatar
I had seen another diagram like that but the 8&2,6&1 are turned around and would like to know the right order.Thanks
Old Nov 19, 2009 | 08:22 PM
in that case, try one. If it won't work, try the other. Running an engine for a few seconds with the firing order the wrong way around won't do much. and the correct order will get all the build up cleared out.
Terry
Feb 17, 2019 11:26 AM
Sparkplugs.com
Sep 1, 2017 03:22 PM
blkwidow
Nov 19, 2012 07:50 PM
andrew65
Jan 24, 2009 05:53 PM
gordoj52
May 9, 2007 03:43 PM
