throttle position sensor adjustment
I don't think there is any adjustment on the throttle sensor.. I would clean the throttle plate first and make sure it opens and closes freely.. if that is your problem.... I am not sure if this helps I need more input...
Is the throttle clean? Open and close ok? Also What code do you have... are all vaccum lines ok? how does engine run? Throttle position sensor is an R&R only no adjustment that I know... something else is wrong let me know
Non-adjustable,
Linkage binding or sticking?, free movement of throttle plate, returns to closed throttle?
TPS properly tightened down?
Check both sides of the plug for damaged/loose pins, pushed out pins/connections?
Check that you have voltage between VREF and SIG RTN at the TP harness connector?
jirvin1
Mar 14, 2014 05:16 PM
