Tube Assembly Fuel Vapour Separator
Hi guys, i recently picked up a 2006 grand marquis im looking to replace a brittle hose "Tube Assembly Fuel Vapour Separator". i cant find the original part, ive tried searching for people who are selling parts but been unable to locate someone in my couple of days search. today i came across some in a crown vic forum discussing the hose, years ago post though. original part number is 8W1Z-9D289-A. I know its been discontinued....but what replaces this? here is the link to the thread im referring to https://www.crownvic.net/ubbthreads/...Number=3580697
junkyard nearby wont sell me one either someone mentioned 9W73-9D289-CA but im not sure. anyone here can help? ive tried a search for the threads here for info but no luck. thanks in advance! |
I know that this probably isn't much help, but I would try going down to a local wrecking yards and looking at other types of Fords (Mustangs, SUVs, and pickups) equipped with the 4.6L. and see if anything off of one of those might be compatible. If you're lucky, maybe you can test fit it on another Grand Marquis in the wrecking yard. Hopefully you will find something that will fit, and maybe use the make and model of the donor vehicle as a basis for ordering replacement tube in the future. If not, maybe you can temporarily patch it up with aluminum tape until a better solution comes along.
| All times are GMT -5. The time now is 05:26 AM. |
