turn signal flasher
Old Mar 3, 2020 | 07:22 AM
badboy368's Avatar
Default turn signal flasher
can anyone tell me where the actual flasher is on my 2003 grand marquis? I have searched, and all i find is where the turn signal fuse is. I need to change the flasher relay itself to a heavy duty one. Thanks for your help.
Old Mar 3, 2020 | 07:31 AM
Default Turn Signal Flasher
If you live near an AUTOZONE store, take it there. Buy the flasher from them, and have them install it.
It's almost always FREE.
I've had the 95 MERC for 15 years, and I STILL don't know where the flasher is located.
Good Luck !!
'95 MERC Engine Bay
Old Mar 3, 2020 | 10:11 AM
raski's Avatar
There is no flasher. Turn signals are contolled by the lighting control module. Not a DIY project.
Old Mar 3, 2020 | 11:20 AM
badboy368's Avatar
I just switched over to LED bulbs in the turn signal / marker lamps, and I am getting a fast flash. Should I switch back? or is there another solution?
Old Mar 4, 2020 | 08:13 AM
Default LED Resistors
Due to the low voltage of the LEDs, a resistor is added to the circuit in order to bring the flash to the proper duration.
Resistor Kits ( includes instructions) are available from Amazon.com . -- not expensive.
E-Z install -- no special tools or skills required.
Picture shows LEDs installed in Parking Lights -- and one Headlight.
LED Headlight Bulb, Passenger Side -- Halogen Bulb, Driver's Side.
Resistor Kit installed in Parking Lights.
4Pcs Aaron 50W 6ohm Load Resistors - Fix LED Bulb Fast Hyper Flash Turn Signal
About 5 years in use -- NO problems of any kind.
And I can SEE !!
Old Mar 4, 2020 | 09:52 AM
badboy368's Avatar
perfect Thank-You very much
babaloo09
Aug 8, 2014 11:32 PM
dc3886
Jan 18, 2008 03:23 PM
april1987
Dec 8, 2007 08:52 PM
pooner88
Jan 22, 2006 08:53 PM
flasher
Jun 24, 2005 09:50 PM
