Wipers won't start up quickly.
Old May 26, 2017 | 09:26 AM
GS38's Avatar
Default Wipers won't start up quickly.
When the engine is warm, the wipers take almost a minute to start working. Do I simply need a new multi-purpose relay module? Thanks in advance.
Old May 26, 2017 | 11:03 AM
When troubleshooting problems, it is best to begin by stating the Year, Make, and Model of the vehicle in question.
Old May 26, 2017 | 12:27 PM
GS38's Avatar
This is a 1999 Grand Marquis GS. I see one available module that is simply a plug-in, and another that has 10 wire leads coming out of it.
Old May 28, 2017 | 06:42 AM
The '99 GS wiper switch/governor are the same as my '95 GS.
You have a wiper switch assembly and a governor.
The switch is on the steering column -- the governor is under the hood.
There are A LOT of contacts on the back of the wiper switch, which may have become corroded. Removal of the switch and a cleaning of the contacts MAY fix your problem -- it's the cheapest option available, so worth a try.
A NEW switch can be had from RockAuto.com -- prices vary.
The Governor is the underhood box with the gray connector -- BIG dollars for this item !!
As of 4:15 AM MST on 5/28/17 there was ONE Motorcraft SW2518 Wiper Governor module available on "close-out" @ $23.09 from RockAuto.
If you miss that one, you might look for a used governor module on e-bay -- the price on the wiper governors is way high @ 118.79 for a Re-Manufactured Motorcraft.
If all else fails, the junk yard is a last resort.
All things considered, I would first clean ALL contacts on the Switch AND the Governor, and apply a film of Permatex Dielectric Grease to all the pins and sockets.
I found that the wiper start-up delay varies with the position of the switch -- if you turn the wipers to the "full-on" position, they start instantly. If you choose the "intermittent" position, the wipers take much longer to start.
Good Luck !!
Old May 28, 2017 | 11:10 AM
GS38's Avatar
Thanks, Merc! You're the best!
Old Jun 1, 2017 | 09:52 AM
Glad to be of help, GS !!
I have completely restored my '95 GS, and am quite familiar with modifications to the suspension and drive train.
I built the car with comfortable, high-speed touring of the Southwestern deserts and the Rocky Mountains as the main objective.
Your '99 has a lot of the same suspension parts as my '95, so I may be able to help getcha goin' with some suggestions for greatly improved ride, cornering, and handling.
Gimme a holler if you're interested !!
valtem
Sep 4, 2013 12:44 AM
anizet
Aug 5, 2013 01:59 AM
gila
Jul 4, 2013 03:27 AM
kim1349
Sep 19, 2009 12:29 AM
281_Law
Apr 21, 2009 12:23 PM
