Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here...
86-91 Grand Marquis CAI
Old Jan 17, 2008 | 06:07 PM
those of you wondering what to use as a cold air intake for there 86-91 Grand Marquis cars. what i have seen that works best is a 1990-1993 Acura Integra cold air intake setup. i got mine for around $30 each off of ebay. you have to cut/modify them a lil bit. i cut the tube off past the bracket welded on it and cut it off past the 2 tube pipe things on it also. here is a pic of how it turned out.
http://i48.photobucket.com/albums/f2...achickenfarmer /Grand%20Marquis/Sandysengine.jpg
http://i48.photobucket.com/albums/f2...achickenfarmer /Grand%20Marquis/DSCF0132.jpg
Old Dec 14, 2008 | 09:16 PM
I just rednecked the intake on my MGM.
Home Depot Parts:
2x - 3" adjustable 90 degree angle vent pipe $8.49 each
2x - 3" no hub couplers from the plumbing section $3.88 each
1x - 4" to 3" adapter from plumbing $1.97
Autozone:
1x - Specter Chrome universal cone air filter $24.99
All told I spent just shy of $60 on this. Already had the duck tape. Though I had to buy some tin snips. That added $11. but I''ll use those for other projects as well.
bent it to shape after trimming the outer pipe of the vent pipe (double walled stuff) and then used a c-clamp to flaten out all the sharp edges from the trimming and duck-taped the works together once I got the angles right for the fit to hold everything in place and prevent leaks along the seems.
Pics:
Front angle:
Side angle:
Old Apr 20, 2009 | 08:19 PM
i thought of a way to get my filter setup to breathe in fresh air. i swapped in a slotted bumper and now thinking of cutting access hole for ducting the air in bumper up toward the filter. just need ducting rising from back of the bumper to the filter area and block off the other side to push more air to the filter side. that way people cant tell me it isnt receiving fresh air and call it a hot air intake.
Old Apr 21, 2009 | 11:36 AM
I was thinking of cutting the washer/coolant tank in half and relocating the coolant part and just extending the ducting to behind the headlamps. Still trying to work out the best location for the coolant tank though.
Old Apr 21, 2009 | 02:38 PM
go to junkyard and get a 1990 fan shroud that has the coolant reservoir mounted to it and get a aero body washer reservoir to mount to the area where the relays are. with that stuff, all you have to do is move the relays to a different spot and opens up all the area behind the headlights.
Old Aug 4, 2009 | 06:22 PM
ok... done cut the bugger in half... here's the pics. Also installed a "hot air shield" of sorts next to the filter. won't stop it breathing hot air, just won't be near as much.
Old Sep 29, 2009 | 03:59 PM
ok... I finally broke down and got the K&N Apollo (and may modify it eventually with a larger snorkel hose).
Pictures will follow the path of the air to the engine...
pics:
First: The snorkel with bell just behind the grill to keep that pure stock look
Next the snorkel from the grill to the air dam behind the grill (had a not so fun time making that hole in the dam and bracket to get enough room to pass the hose through)
Then from the air dam to the filter box:
The air box ... err cone:
And finally the dryer hose (3 inch hard aluminum) that will eventually be replaced with some mandrel bent aluminum pipe (I hope):
And there you have it. And I can still drive in water up to the grill and not drown the engine.
Old Oct 9, 2009 | 06:59 PM
Final mods - I hope.
Pics (from grill to engine):
fiatochast
Jan 12, 2009 10:15 PM
audieurozapc
Dec 16, 2008 09:34 PM
eurozapchasti
Dec 15, 2008 02:32 AM
MarinerTX
Nov 10, 2005 03:36 PM
