header help
I'm looking for a set of headers that will go good with my 1998 grand marquis. And suggestions?
Headers On A Grand Marquis !??
Originally Posted by grandmarquis98
(Post 16483)
The stock exhaust manifolds can handle all the power that you can get out of the 4.6 V-8 without extensive modifications to the engine. To get the most from your stock Grand Marquis exhaust system, invest in a set of dual exhausts -- Walker H-pipe, 2" x 3.5" x 21" Magnaflow Glasspacks, and Walker Tailpipes. Part numbers for the 1998 Grand Marquis = H-Pipe = Walker #50412 Gaskets (2)= Fel-Pro #60924 Mufflers = MagnaFlow #18134 MagnaFlow #18134. Aluminized steel construction prevents rust-out. Proprietary "RockWool" packing resists blow-out. Overall length - 26". Muffler body - 22". Muffler overall diameter - 3.5". 2" center inlet. 2", straight-through, perforated core. 2" center outlet. Perforated core with NO LOUVERS that restrict exhaust flow. Reversible - non-directional - flows equally in both directions. Mufflers are very well made, with perfect welds and solid construction. Once installed on a 4.6 Liter FOMOCO V8, the sound is excellent, with a powerful rumble when accelerating, and a smooth tone at highway speeds. Never noisy or objectionable -- just a mellow, powerful tone from idle to wide open throttle. 80mph = 2000 rpm on the 4.6 Liter V8 -- and the sound inside the car allows for normal conversation. Outside of the car, the sound was measured with a Sound Meter: With the Meter at same height as the pipe tips - centered between pipe tips - 3 feet back. 88.7db @ start-up -- 84 db @ warmed-up idle. Not too loud - not too quiet - just a pleasant tone from the V-8 engine When compared to other glasspacks and performance mufflers, the MagnaFlows meet all of my requirements for design, construction, and performance -- and the PRICE/PERFORMANCE ratio is outstanding ! Left Side Tailpipe = Walker #56007 Right Side Tailpipe = Walker #55155 This combo will yield 22 hp over the stock exhaust, as tested with a G-Tech Pro. |
https://cimg3.ibsrv.net/gimg/www.mer...7606bab416.jpg
Walker H-Pipe; MagnaFlow #18134 Glasspacks; Walker Tailpipes; Superior Tips. https://cimg2.ibsrv.net/gimg/www.mer...6b41ebbd19.jpg Custom Dual Exhaust Exits; Superior Tips Checked out those Grand Marquis headers at that website -- COOL headers, but ELEVEN HUNDRED DOLLARS per set !! NOT a good idea, OR a wise investment. A well-made, street-legal, high-performance cat-back system = 20-24 HP = about $300, installed. |
Thanks
I was wanting to know the same thing....you answer was very helpful. Thanks !
Here's a pic of the dual exhausts on the 95 MERC;
https://cimg0.ibsrv.net/gimg/www.mer...f5d66ee606.jpg Walker H-Pipe; MagnaFlow Glasspax; Walker Tailpipes. I got all of the parts at Amazon.com -- Installed the H-Pipe myself, then had the rest welded up at MufflerMasters, Avondale, AZ. Strong rumble, smooth tone; no droning. |
| All times are GMT -5. The time now is 12:44 AM. |
