MF Help & Suggestion Center Need help with MF? Ask... Have a suggestion to better MF? Tell us here...
Air suspension
Old Nov 30, 2019 | 04:08 PM
James Perrino's Avatar
Default Air suspension
Hi there, I have a 2003 Mercury Grand Marquis. It has new airbags in the back for the suspension. However, recently the air compressor will work for a few days and then for a few days it will not work.. When it does work everything is fine and there are no leaks. What could be the problem?
Old Dec 1, 2019 | 08:28 AM
Default Air Bags
Take it back to the shop that installed the "new" air bags to have it checked out.
Like No Other
Old Dec 15, 2019 | 03:52 PM
it was in 2015 when the new system was put in. Could it be the level sensors? I changed the relay under the hood and changed the air compressor. It worked for a day after doing that but the problem started again. All this work I can do myself. I just want a push in the right direction. This was my parent's car. I've never been to a mechanic in my life. I fix everything myself. If I can't figure out the problem I will just install coils and be done with it
sheriya
Mar 28, 2013 01:52 AM
_Brian_
Jun 30, 2011 02:53 PM
Bob-18854
Jul 10, 2008 07:55 PM
bigred
Jun 7, 2008 10:29 AM
Ga98LS
Sep 2, 2007 08:35 PM
