2002 front upper ball joint help
Greetings All.
im looking for a little guidance here. The answer seems impossible to find for me. I have a 2002 mountaineer 4.6 L, I need to replace the upper and lower ball joints in the front. The Upper ball joints I purchased do not have a retainer ring for the bottom side of the control arm. When I got involved in the job last night I realized that the factory joints (Im assuming factory, i bought it used) HAVE retainer rings. I contacted my supplier and questioned him on it and he told me that the ball joint he sent me is the correct ball joint for the vehicle and to go ahead and press them in, disregarding the old retainer rings. now I start doing some online research and I’m finding a lot of differing answers. some sites sell them with the retainers some sites sell them without the retainers. Other sites say that it’s not possible to change the ball joint without changing the entire control arm. Is there anyone here with personal experience that can tell me which direction I should go? I appreciate any replies. Ron |
Ball Joint Replacement
Originally Posted by Rrizz
(Post 24394)
Greetings All.
im looking for a little guidance here. The answer seems impossible to find for me. I have a 2002 mountaineer 4.6 L, I need to replace the upper and lower ball joints in the front. The Upper ball joints I purchased do not have a retainer ring for the bottom side of the control arm. When I got involved in the job last night I realized that the factory joints (Im assuming factory, i bought it used) HAVE retainer rings. I contacted my supplier and questioned him on it and he told me that the ball joint he sent me is the correct ball joint for the vehicle and to go ahead and press them in, disregarding the old retainer rings. now I start doing some online research and I’m finding a lot of differing answers. some sites sell them with the retainers some sites sell them without the retainers. Other sites say that it’s not possible to change the ball joint without changing the entire control arm. Is there anyone here with personal experience that can tell me which direction I should go? I appreciate any replies. Ron I've done a complete Front Suspension restoration on The 95 MERC, including new upper & lower Ball Joints, urethane Control Arm Bushings, Springs, Shocks, and Sway Bar on a Grand Marquis. The ball joints from RockAuto.com were easy to install, and their prices and selection are hard to beat. Good Luck !! https://cimg1.ibsrv.net/gimg/www.mer...f27ccadd45.jpg Custom Dual Exhaust Exits; Superior Tips |
Rock Auto is where I bought the ball joints......
with no retaining rings. they do not list an upper ball joint for my 2002 that has the ring |
Mountaineer Upper Ball Joint
Look again, my friend --
Scroll down to "Heavy Duty" = MEVOTECH TXK 80008 4 Pictures show Upper Ball Joint, complete with new snap ring and mounting hardware. Mevotech makes good stuff. https://cimg9.ibsrv.net/gimg/www.mer...d8bb92bac3.jpg 95 MERC Engine Bay |
Ahhh.. now I see. Curious why they have 2 different joints for the same vehicle?
any ideas? |
2002 Mountaineer Ball Joints
In my experience, they make different quality grades for many parts -- I ALL-WAYS go for the top-quality offerings, which is often better than original equipment.
Example: 95 MERC upper ball joints from the factory have no grease fittings -- I installed MOOG Greaseable ball joints, tie-rod ends, sway-bar links, and idler arm. 17 grease fittings, total. I use LUCAS X-TRA Heavy Duty Grease -- Pix will tell ya why. https://cimg4.ibsrv.net/gimg/www.mer...08c53b76af.jpg LUCAS X-TRA Heavy Duty Grease. Doesn't wash out !! https://cimg1.ibsrv.net/gimg/www.mer...4b844a4007.jpg LUCAS X-TRA Heavy Duty Grease. Doesn't freeze out !! |
Ball joints for 2000 marquis
What name parts did you use? And did the fit good if they are after market?
Get The GOOD Stuff !!
For both Upper and Lower Balll Joints, it ALL-WAYS pays to use top-quality parts -- for safety, reliability, and performance.
Buying the cheapest part available is just foolish -- and there's NEVER a good excuse for doing stupid stuff ! In the case of the 2002 Mountaineer, the smart choice would be Ball Joints from MEVOTECH or MOOG, which come with all hardware (snap ring, grease fitting, nut, and cotter pin) necessary to do the job PROPERLY. https://cimg3.ibsrv.net/gimg/www.mer...b8ce56bc42.jpg '95 MERC at Flaming Gorge, Utah. |
