2004 temp blend problem
</>On my 2004 mountaineer the temp control stopped working yesterday. No matter where you set the hot/cold blend **** it blows hot air. I tried selecting A/C and MAX A/C but still only get hot air. I can switch to floor/dash/defrost vents OK but it is always hot air regardless of the vent selected.
With the ignition switch ON I can hear what sounds likean actuator motor when I rotate the temp control **** coming from the drivers side under the dash.Edited by: carolinatim
gmman
Jul 11, 2009 03:05 PM
