2006 Mountaineer stalling
Old Apr 17, 2016 | 08:15 AM
treasures4u1's Avatar
Default 2006 Mountaineer stalling
My engine light came on and error code is P0401 Exhaust EGR Flow Insufficient. The car is misfiring and will actually quit as I am driving down the road. I have done some research and have come up with that maybe I need to replace the GSR valve? Can anyone tell me if that is so?
Thanks
Old May 10, 2016 | 08:07 AM
conan312's Avatar
It seems to me that the code Or the EGR valve does not match the symptoms you are experiencing with the vehicle itself. A frozen EGR can cause pinging and detonation. Misfiring is not a symptom of a bad EGR. The vehicle stalling definitely not. The only time I've had a the vehicle's engine cut out while in the act of driving was from a faulty crank sensor. A lot of the symptoms sound electrical to me.
Old May 21, 2016 | 06:26 PM
leftoverture's Avatar
I would agree with Conan. Sounds like a professional diagnosis might be in order.
Old Jan 15, 2019 | 02:16 PM
Jonathan Scott Brodeur's Avatar
Thanks
did you ever fix this problem? i’m having the exact same problem. ive replaced egr, 02 sensors, coil pack, spark plugs and wire set and pcv. i think i’ve got a wire chafing somewhere
Old Apr 22, 2019 | 03:24 PM
ronaledsmith's Avatar
I've been faced the same victim around 5 months ago.
It was really awkward.
mikeasis
Aug 8, 2018 03:05 PM
cowboy1169
Jun 13, 2017 12:57 PM
dschutt
Jan 18, 2014 10:38 AM
jswift
Oct 14, 2009 01:29 PM
jenlegs
Jul 31, 2008 02:28 AM
