98’ Mountaineer Thermostat Housing
Old Nov 23, 2007 | 01:14 PM
Ajwheeler66's Avatar
I have been having troubles with my thermostat/housing. It has been leaking coolant underneath the housing, we have replaced the thermostat and the gaskets a number of times and cannot seem to get it to stop leaking. Has anyone else had troubles like this or can help me.
Thanks
Old Jan 1, 2008 | 01:33 PM
JedClampett's Avatar
I just replaced a thermostat on my 97, and having had your problem in the past, I (very patiently) scraped both surfaces until they were completely free of old gasket, etc, then cleaned both surfaces with rubbing alcohol until the white cloth was free of grease and dirt. I then used a "blue" sealant with a Fel-pro gasket, and only lightly tightened the bolts, left overnight, then torqued to spec. no leaks at all! < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-45";
urchinTracker();
Old Jan 18, 2008 | 11:30 AM
the best silicone sealer i have used is permatex Ultra Black. it can be used just about for anything you need to seal up. it cant be just permatex black from wal-mart... the good stuff is the Ultra Black
Old Jan 25, 2008 | 11:47 PM
conan312's Avatar
I agree with Jed. Make sure the old gasket is completely removed, (housing and intake) Fel-pro is always the way to go, and don't over tighten. Automotive sealants are color coded for differrent applications. Blue is the right color to use, but not alot. Maybe just enough to hold the gasket in place while replacing. Don't forget curing time like Jed said. Let us know. P.S. make sure the thermostat is seated properly.Edited by: conan312
rdondes
Nov 27, 2019 01:06 PM
rfellmanjr
Apr 30, 2010 07:00 AM
rfellmanjr
Apr 12, 2010 07:24 PM
dave59330
Feb 16, 2009 08:45 PM
92Mercury
Jan 5, 2009 07:49 PM
