ABS Light Comes on When rapid acceleration
Old Aug 16, 2009 | 09:07 PM
Jrock's Avatar
Default ABS Light Comes on When rapid acceleration
2004 Mountianeer v6 - ABS light comes on when accelerated rapidly. Also motor shakes when first cranked, after acceration clears up until reaching a stop. Help????
Old Aug 16, 2009 | 09:55 PM
you probably have a vacuum leak somewhere. Also, check that your spark wires are connected good at each end. It could also be bad/clogged injectors as far as the shaking part goes. You may also have a flaky speed sensor on one of the wheels (or whatever the lock-up sensor is that engages the ABS). Check the fluid levels in the brake system as well. if the fluid is almost too low, it may light up due to low level detection.
Old Aug 19, 2009 | 06:56 AM
mounty2004's Avatar
Can you please let us know where is the vacuum and speed sensor located. Thanks.
Old Aug 19, 2009 | 08:11 AM
vacuum leaks could be anywhere in the system. just make sure everything is connected according to the diagram under the hood. The speed sensor should be coming out of the transmission for the speedo and cruise needs, but the abs sensors might be on the hubs (spindle portion actually). I'm not real up on abs systems since I've never had a vehicle with one so someone please correct me if I'm wrong.
rocasan
Oct 23, 2012 01:36 PM
rocasan
Oct 23, 2012 01:12 PM
tthcare
Nov 21, 2009 08:00 AM
cougar01
Oct 15, 2006 07:13 PM
soldout162000
Jun 30, 2005 03:06 PM
