Alternator Problems
Old Aug 3, 2011 | 10:46 PM
sminnis's Avatar
Exclamation Alternator Problems
Well, here it is. One day my "Check Charging System" and battery light came on. When I checked, I had no voltage output going to the battery. I ordered a alternator from Napa and installed it. Right when I started it the "Check Charging System" came on and the battery light stayed on.
I have brought it to a shop and they pulled a P0620 code. I have checked the B+ wire from the alternator to the battery and have very little voltage drop, if any. I have checked the grn/org wire from the Alternator to the PCM and no Voltage Drop. I checked the org/blu wire from the Alternator to the battery, and have no voltage drop.
I back probed the org/blue wire while the engine is running and show 14.1 volts. I back probed the grn/org wire while the engine was running and showed 13.8.
The all data wiring diagram shows and 8-9v at the PCM. I have unplugged the connector at the alternator and checked the grn/org wire with the engine running and still show 12v.
Here is my question, I think the PCM may be bad, but I called to price one and it the dealer quoted me $1600.00. This is not something I want to guess at. Does anyone have some more ideas for me to check before I start looking at replacing the PCM? Should I have only 8-9v on the grn/org wire?
Thank you everyone in advance.
Steve
lugnut
Oct 24, 2017 11:20 AM
addison_ii
May 12, 2008 01:29 PM
J0n-
Feb 17, 2008 02:20 AM
lbrown
Nov 9, 2006 11:47 PM
lbrown
Nov 9, 2006 05:57 PM
