Brake Shoe Replacement
Old Dec 26, 2007 | 09:07 PM
bearsfan's Avatar
Does anyone know of an online repair guide for 01 mountaineer? I need to change the front brake shoes. I have done a few brake jobs include rotors and master cylinder, so I basically know brake systems. Does anyone no if there is any special trick or extra step that might need to be taken for this vehicle? I would image that there is not but any input would be apreciated.
Old Dec 28, 2007 | 06:00 PM
bearsfan's Avatar
So I changed the brake pads on the front today, but there is a metal on metal noise coming from the driver side wheel. Do you think this could be the rotors? Also the brake pads did not completely fix the problem there is still a lesser grind when stopping, but you can here it.
Old Jan 6, 2008 | 05:42 PM
bearsfan's Avatar
Does anyone have any suggestions on how to remove the rear rotors? I have backed the emegency adjustment all the way both ways and the rotor will not come off. This is really becoming a pain in the ***.
Old Jan 18, 2008 | 11:22 AM
if you are still around... have you looked to see if the back plate behind rotor is rubbing or has anything between it and the rotor? i have come across the winter months vehicles get road salt and gravel between there and cause noise and grinding.
Old Jan 26, 2008 | 12:30 AM
conan312's Avatar
The rear drums, after you back off the adjuster, needs afew real hard whacks with a mini sledge or a very heavy hammer. Hit the drum only on the face and hit it in a circle all the way around. Watch out for the studs. That should unfreeze them. As for the front, did you have the rotors resurfaced or replaced? Let me know.
mannybetty
Jul 3, 2013 09:15 AM
mstorrs
Jul 31, 2012 07:05 AM
stangcbr
May 15, 2010 10:37 PM
Albertaman
Aug 30, 2005 02:07 PM
quaternion
Oct 21, 2004 04:23 PM
