Coolant leak at oil cooler
Old Jan 1, 2008 | 01:27 PM
JedClampett's Avatar
I have a '97 Mountaineer -- just replaced the thermostat (it was over-cooling, which can cause the EGR to throw a fault, apparently). All was well for a few days (no check engine light!), then I noticed a small coolant leak, dripping from the oil filter. I did do a cooling system flush and added new (it was rusty; previous owner apparently a slouch). I'm wondering if anyone else has had this issue, and what's the fix? My local dealer wanted an arm and leg to do the thermostat and flush, so I avoid those dudes. Greatly appreciate any help. This is a 5.0 engine.< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-45";
urchinTracker();
Old Jan 18, 2008 | 11:37 AM
i would backtrack the coolant leak and see where it is coming from. when you did the other repairs, you might not have gotten the hose clamps tightened well enough.
eeek2014
Nov 13, 2014 04:24 PM
dmerc95
Feb 16, 2012 04:02 AM
the james
Jul 17, 2011 03:55 AM
patmac6075
Oct 15, 2010 11:40 PM
tycoonmonsoon
Mar 5, 2010 05:10 PM
