door not locking
Old Jun 10, 2005 | 07:41 PM
bsears's Avatar
I am in the process of buying a 97 Mountaineer. Have 1 problem.
The driver's side door won't lock. Would this have anything to do with the keyless entry keypad? The current owner (less than 1 month), doesn't know why it doesn't lock and also never had the code for the keypad.
Any ideas out there?
Old Jun 11, 2005 | 02:16 PM
Patrick's Avatar
Administrator
why is the current owner selling it after only a month? that would concern me as well
Old Jun 13, 2005 | 12:17 PM
bsears's Avatar
A good ? His personal situation dictates selling at this time.
Old Oct 27, 2005 | 02:22 PM
TechBob's Avatar
I recently purchased a 97 Mountaineer AWD and my driver side door doesn’t lock sometimes if I bring the power locks up and down a couple times it will lock. If any one here can answer this question it will be appreciated.
Old Nov 4, 2005 | 04:07 PM
TechBob's Avatar
Found the problem, the key in sensor on the ignition switchwas hanging out of it's mounting, so I reinserted it and taped it in place so it would not slip out again. the sensor is nothing more then a coper contact point when the key passes over it it makes ground the reason that the door chimes was going off when you open the door is because this sensore is just hanging there and grounding out this made the computer think you where locking your keys in the car.
63sxxl
Dec 5, 2011 06:42 AM
Ty in Arizona
Oct 1, 2011 06:58 PM
jvitello
May 23, 2008 09:43 AM
Robyn
Jul 2, 2006 11:20 AM
VaDancer
Mar 20, 2006 02:32 PM
